Shift pattern on a 544 gear drive without the Forward/Reverse looks like this-
R 2 4 1 3 5
I would bet that your's is the same, but the reverse position is probably omitted. It sounds like the Forward/Reverse part is working OK, but your main transmission is stuck in a gear. Remove the large battery box cover under the steering column between the clutch and brake pedals. Remove battery. You'll then see the external shift linkage. There will be three upper arms, three rods, and three lower arms. With the gearshift lever in nuetral (centered) they should all line up with eachother. If one is up or down, try to move it back to center by hand. Do this on level ground with the Forward/Reverse lever in nuetral, and be ready to get out of the way if it starts rolling. Your external linkage may need to be gone through, they were known for this sort of problem. Case-IH may still offer a rebuild kit with updated parts.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
