Re: IH 631WA running gear
Posted by Janicholson on October 19, 2007 at 15:57:37 from (66.173.50.89):
In Reply to: IH 631WA running gear posted by dgm51 on October 19, 2007 at 09:34:21:
I do not know that gear particularly, but many had roller bearings on a straight axle. The end play was taken up by a thrust washer on both inside and out. Many had slotted nuts on the spindle threads to allow adjustment. I would suggest taking one apart to see the condition of the thrust washers. Some were steel, some were brass. There should be about .005 to .007 end play in the hub on the bearing. If there are tapered rollers, they should be tightened so that all clearance is gone, then just a bit tighter (no more than 1/6 turn. use Mobile1 synthetic grease, or Ford spec graphite based chassis and wheel bearing grease to assemble, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
