Also- a good idea would be to drain and refill the oil in the injection pump. A large percentage of these have bad seals from the primary pump and will fill the injector pump housing with deisel. Prolonged running with diesel instead of oil or heavily dilluted oil in the pump will ruin the pump, and also if it leaks pretty bad and is never drained it could get full enough to leak past the front seal, causing the engine crankcase to get deisel in it. The injector pump uses the same oil you have in the engine.
If your pump does indeed have diesel in it, go to the Red Power site and do a search for posts by a guy called "MB_Cat" I believe. He has a post about how to replace the primary pump seal to cure this. The post has pictures as well as the IH part number for the seal. It's still available, I got one a couple years ago for my 650D.
Another note- whenever your not trying to start or run the tractor, leave the fuel switchover lever in the deisel position. If it's left in the gas position it'll run the battery down....guess how I know that???:)
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
