Use an analog meter.
Posted by Bob on October 20, 2007 at 13:49:39 from (69.178.229.154):
In Reply to: voltage at alternator reading posted by keith smith on October 20, 2007 at 13:42:33:
The noisy electrical systems on these old machines often give digital meters a sick headache.
Even a cheap analog meter is more than accurate enough for this use, and won't be affected by the EMI.
You want to see about 14.5 Volts on the large output stud, and the #1 and #2 terminals with the engine running.
With the engine STOPPED, the voltage on the #1 ("switched excite") terminal should drop to zero.
If it doesn't drop to zero, the alternator will remain "excited" and drain the battery.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
