Posted by KEB on October 22, 2007 at 13:41:50 from (192.91.171.36):
In Reply to: Gasket material? posted by Mike CA on October 22, 2007 at 07:56:49:
Thin gaskets without much give (like paper or composite) are used where you have smooth, solid mating surfaces. Thick gaskets with a lot of give (like cork or soft rubber) are used where one or both sides of the mating surface can flex, such as a valve cover or engine side cover. Thin hard gaskets, or a material with a known amount of compressibility are used where a dimension has to be maintained across the gasket joint. A head gasket would be a good example here.
Your bolster would use a thin paper or composite gasket as it has machined mating surfaces.
RTV gasket maker is good stuff, but don't get carried away with it. More is not better, especially when it oozes out on the inside and a chunk breaks free.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
