You can use your choice of "MY" diode, "BobM's" "idiot light", or "JohnT's" resistor anywhere that's conenient in the wire feeding power from the ignition switch to the alternator's #1 "switched excite" terminal.
You only need ONE of those three options, and ALL work EQUALLY WELL.
If you want an "idiot light" in the dash, go that route. USe a #194 lamp, or one of equivalent current draw.
If you want to use a resistor, go that way, but be advised it will get HOT, if the key happens to get left on, so you need to mount it so that it can dissipate the heat without melting any wires.
That's why I almost always use the DIODE... it provides protection to the alternator if there's a problem in the high-current part of the charging system wiring, and prevents the engine from "running on" when the ignition is switched "OFF", but it doesn't get HOT, so it can simply be covered in heat shrink tubing, and taped up along with the other wires in the harness.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
