Sure is a pain to get to those belts! I did mine while I had my radiator off so it wasnt to hard on mine. If you have too you can take the radiator loose from the top support and lean it out some to give you some extra room.
I orderd my belts from OEM, I think they cost about $12 each. I didnt measure them but they were the correct size. So if you cant get the belts local you can always order them. Cut the old one off and take it in with you. Might as well replace both belts while your at it. Neither of my belts are cogged now but the old alt belt I took off was.
Just as hard getting it back on and getting it tight. I had to get a friend to help and used a block of wood and a longer piece of wood to use as a lever to get the right tension.
You might also want to check the oil in that fan hub. Theres a little screw on the side you add oil in then turn it on the side and let the oil run out until it stops.
If you do have to take the radiator off you can get new hoses at tractor supply. Removing the radiator isnt a fun job either but you know if your fixing things up you might want to go all the way and flush the radiator out and get the new hoses.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
