Re: IH 464 Running Hot
Posted by the tractor vet on October 25, 2007 at 08:20:30 from (99.167.210.1):
In Reply to: Re: IH 464 Running Hot posted by jjohnson on October 24, 2007 at 22:44:33:
Well we are pulling at straws here but when they recored the rad. did they use a core that may not have enought tubes or smaller tubes thus it has lees cooling area or less coolant then org. Nex check ing. timing for total advance at rated RPM . Next remove the hood and remove the thermostat and fill only to the top of the neck of the therostat housing with the top hose off and remove the fan belt so the water pump does not work . Do this with a cold engine . Start the engine and rev it up if it is a cracked head block or blowen head gskt. it will look like old faithful and shoot water out . Then ya know for sure . Next try higher test gas this will run cooler then req gas. Also check for a smashed exhaust pipe or pluged muffler.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
