Well iam betting that that E is really an B as they never used a E class bore . SOOoo ya need three std. bore sleeves and three oversized sleeves . All I H gassers have harden seat and stelite valves . Adding SNAKE OIL really does nothing . The use of a non low ash oil is what causes the exhaust valves to torch . ANd the use of Hightest gas is required for working the tractor as it burns cooler and longer . giving better power and lower heat on the top of the pistons . Trust me here as i have worked on a lot of the gassers and we still run two 706 gassers . Now here is some food for thought , To get away from two different size sleeves You may want to think about maybe maken her a 291 . This can be done by having a GOOD machine shop bore the block and getting the sleeve and piston set that is made to take a C263 out to a 291 . Now there are a couple things that will need changing along with this set up , one is getting the Dist recurved to the timing spec.'s of a late 291 engine and myself i like to rework the carb by reaming out the main jet .001 , for this i had a local drill bit mfg. co. make me up a ream for this . AND that is all that needs to be done and ya fallow the skirt to wall clearence that i posted before and run the Low Ash oil and the 93 octain gas and break that engine in for 35 -40 hours with light to med loads and it will give ya years of service .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
