Look at the parts diagram --caseih.com-- follow the instructions to search for parts. The pump needs to be taken out to service it. One item not mentioned is if the lever has loosened on the shaft, it might cause the problem. THe most likely is a pressure relief valve stuck open (a piece of dirt) these pumps would not be damaged by 90 wt, but in cold weather they might have operational reluctance. Some use ready rod (allthread or threaded rod) to lower the pump after all the elbows and the lever are removed. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
