Re: 1066 no steering, brakes when cold
Posted by the tractor vet on October 29, 2007 at 07:56:11 from (75.19.120.169):
In Reply to: 1066 no steering, brakes when cold posted by rplanty on October 28, 2007 at 19:42:49:
Well like others have said and if the filter is clean and the screen is clean then i would have to say that ya may have a leaking sump check plug or ya may have some sticking valves in the MCV . ANd may need a new spring kit and a real close look at the valves . Not sayen that you could not do the job but ya will need atleast one special hyd fitting a test gauges that will read 600 lbs To set the pressure reg. spring as it may need to be ground of to reduce pressure or may need to shimmed up. I had one 966 that was doing the same thing and foundthat the pressure reg valve was scored and stuck.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
