I was sort of having the start of the same trouble on my 544,, I had it lent out pulling a hay rake for a while, they kept checking teh fluid and it was full, when they brought it back they told me what it was doing and I felt it hard to turna nd squeeling,, I thought great ,, I checked the fluid with the engine off, it was full, [this is a hydro],, looked at the book and it says check it with it running, , it was a little over 3 "gallons" low,,, I think I caught it prior to doing a lot of damage I hope, time will tell,,,
I looked at the book trying to figure out what I was going to need to replace or repair,, I came to the conclusion it would be the flow divider valve /control-pilot- valve valve,,, on my tractor the book shows it to be [and I found the valve unit] on the left side of the tractor in front of your feet, follow your lines, you wil see the unit,
the book shows a test try to turn your wheels with teh engine off,,,if the steering can be accomplished in both directions control valve is working,, NO steering can be accomplished if the control valve is stuck on center,a control valve stuck off center will allow steering in one direction only..the relief valve is in this unit,,
hope that helps, I dont know if I can scan the page and post it the same as a picture,, good luck,
I know it also shows that you can put a gauge on the outlet and test pressure ,,
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
