You should be able the turn the engine by hand. I would squirt some engine oil into each cylinder and see if you can turn the engine by hand. You may need to use the starter to get the cylinders coated with oil then see if you can turn it by hand. Does it show any oil pressure when using the starter to crank it? You can reinstall the plugs and see if it will crank with the plugs installed. If it won't, I think you will need to pull the head. Before you do that put another help question on the Farmall forum. It may be less work to pull the pan and check your oil pan for metal particles. You could have some bearing issues. If you do find metal particles I would pull one bearing cap at at a time and inspect it. Reinstall and retorque it if looks ok. Make sure you have good battery cables 00 if you're using 6 volt battery and soldered lugs. Was this engine recently rebuilt? They're hard to turn when everything is new, but you should still be able to turn it by hand. Hal
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
