If the seals in the front of the transmission are leaking it a pretty easy fix.The castings that hold them are removeable from the clutch housing. First remove the 2 metal covers,remove all plbg from the pump,take the 2 cotter pins out of the pump drive and remove the drive,remove the four bolts that hold the pump up in place, the pump is rather heavy about 100lbs.I use a floor jack to lower them but be real carefull as they will fall over when the pump leaves the casting.Next disconnect the U joint at the transmission,remove the 2 bolts that hold up the throw out bearing,Block the clutch pedal down then you can remove the shaft,There is bolt in the yoke on the top shaft,one the bottom shaft place a square piece in the drive slot and smack it with a hammer the thread is right hand.then you can remove the castings that hold the seals. Just reverse the proceedure for reassembly. The castings should be marked top make sure you get them right. CIH has the seals,think there about 20 bucks for both,Take your time and be carefull with the pump.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
