Posted by SteveNH on November 04, 2007 at 06:50:00 from (71.255.155.132):
Good morning. I have been sifting through the archives to research my hydraulic pump whine problem and came across a few interesting posts. I am going to drain the reservoir a little and see if I can clean out the bypass behind the allen screw on the right hand side of the hydraulic assembly.
I changed the hydraulic fluid and noticed after working everything (tractor and hydraulics) I am a little lower on hy-tran fluid, when I got the tractor it was 1/2 full. If the oil is leaking through the pump where does it end up? I am smoking a lot, more-so at idle rpms. Will the hy-tran get sucked in and burn? It isn"t leaking out anywhere that I can see. Someone posted a part number for the seal that is available at Napa so getting it to change out shouldn"t be a problem.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
