If you have tractor split in front of transmission case, remove the bolts from main shaft rear bearing cage. Then push shaft and bearing cage to front(watch the shims behind bearing cage)when it clears at rear move shaft into a position to be lifted out the top. Don't know what your doing but shaft can be removed from rear also. Bull gear has to be moved out of way and differential removed. main shaft bearing retainer and the snap ring on shaft moved forward. Carefuly drive rear bearing forward until it will slide on shaft. Slide shaft to rear out of the gears and bearing. If there's a chance anythings not okay on transmission counter shaft I wouldn't recomend the last, because if there is a split at front will be needed anyway.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
