Posted by Nat 2 on November 05, 2007 at 06:16:26 from (64.80.108.53):
In Reply to: 450 Shifter lever posted by glennster on November 05, 2007 at 06:11:54:
Looking into that dark cavity through an itty-bitty hole, you may not be able to see down far enough to see the lube.
The "grease" is likely just 50-year-old gear lube that's built up on the rails.
There is a level plug on the left side of the tractor for the transmission lube. If you pull that and clean-looking thick oil runs out, you're fine.
It may not be a bad idea to get a manual so you have reference for all this stuff, and to change the gear lube in the transmission and rear end of your tractor. Running it dry is a bad, very expensive, idea.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
