Posted by Janicholson on November 05, 2007 at 18:41:39 from (66.173.50.107):
In Reply to: 1954 SH posted by george pickering on November 05, 2007 at 16:49:09:
Yes. THe position ot the drive (from pump to distributor must be as it was. How to get there. Pull #1 plug and turn the engine till it blows your thumb out of the hole. (slow bumps on starter) then put a piece of copper wire 8" long into the hole to feel for TDC. Rotate until almost to the top and then look at the pulley timing marks. Set it at TDC. Pull the pump with the distributor on it out of the hole and turn it so the rotor points to the 1:00 o'clock position when the pump is in all the way. Some trial is needed due to the spiral (helical) cut of the gears. Then bolt it together and re time the ignition as in the book. You are then good top go. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
