Posted by Janicholson on November 06, 2007 at 16:56:54 from (66.173.50.169):
In Reply to: '43 H clutch posted by dan.160 on November 06, 2007 at 14:56:08:
Simple, or complex. It depends on thie following action. Go to the tractor with a measuring tape, or ruler. with your hand, push in on the clutch pedal until it changes its feel to be much harder to push. (from easy to hard) When it is at that spot, measure between the casting of the top of the trans (platform) and the spot on the pedal that touches the platform when the clutch is not being pushed. It should measure 1 to 1-1/4 inches. This is freeplay, and is necessary to keep the fingers off of the throwout bearing when the clutch is not pushed. Adjust the length of the rod connecting the pedal to the arm on the housing to make this measurement correct. If it is correct, the tractor will need to be split to repair the clutch Pressure plate (by replacing it) it may have cracks or warpage that prevents proper disengagement. Good luck, it is probable that the adjustment will do the trick. Heat the turnbuckle if it is frozen, they do get rusty. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
