Posted by Janicholson on November 07, 2007 at 06:06:41 from (199.17.6.122):
In Reply to: Live Pump posted by Allan In NE on November 07, 2007 at 01:53:30:
Yes. The key is two parts of the problem. First is the status of the end frame bushing on the gear end. If it has more than .001 clearance (usually in the direction of gear thrust-kind of a diagonal direction)it will need to be rebushed. Check fopr housing wear also, if the gear teeth have scraped into the housing, it is usually toast. If the bearing is great, then go next to the seal/shaft.
The seal needs to be looked at for a replacement ("O"ring, or lip seal) and the shaft (if grooved) needs to be speedy sleeved. The housing may need to be bored out to accomodate a speedy sleeve if there is an "O"ring seal. Best of luck, Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
