There are several possible problems. A 51 super C has (from the factory) a 6volt positive ground system. with a generator, voltage regulastor, amp gauge, and a starter switch using a rod to mechanically connect the contacts inside (at the starter). If yours has had an alternator put on it from a automotive/truck application, it will (most likely be 12 volt negative ground.
If you put the battery in incorrectly, with either system, turn it around.
If the sparks were serious and you left it connected, things may be toasted a bit and need some diagnosis. The ignition switch can go bad, but it usually fails by not working, not by staying on. THe sparks fron the ignition being on would not make you excited they would be mild little sparks. Let us know if you have an alternator retrofit, or stock system, or what. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
