The "O"ring is under the gear, (it has to come off), but it is also inside the housing, and the housing must be split (longways) to get the shaft out of it. Once there, the "O"ring needs to be pulled out of its groove in the housing (a stiff thin wire works, or a dental pick). Look at the shaft closely if there is a groove in it, a speedy sleeve needs to be pressed on to resurface the shaft, and the housing will need to be machined out to allow the speedy sleeve to enter, and the "O"ring to fit deeper. I think NAPA will have, or get the sleeve. I do not think there is a kit, but I might be wrong on that. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
