When Liftalls get into the prime of life (working well, but many hours)the release of the lever seems to be jerky under high load. Two solutions come to mind but are not tested. One easy, one hard. EASY: stiffen up the rod controlling the lever. The rod flexes enough to allow springing in the length of the rod and this seems to be a marginal way to be delicate in control the lever. It is ugly, but a test of the idea might be to use a Vicegrip and "clamp" a 1/2" diameter rod near the lever end of the regular control rod and use that to "parallel" the normal rod to see if better control results from a stiffer rod. HARD: within the Liftall there is a spool valve the lip on the spool that closes off the return of fluid to the resevoir could be modified with a Dremel grinder on one edge to allow valve movement to open a smaller channel as it begins to relieve pressure. Unless you are pretty sure of what you are doing with spool valves/hydraulics, this might be a bad idea. (consulting a good older hydraulic expert to assist might be good as well) JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
