Items not mentioned so far include the current oil pressure (if less than 20 PSI cold, and dropping from there it is not typical and indicates problems. If it has strong pulses in the needle movement at idle, it is also an indication of bearing failure.) The changing of the oil should include a scraping around in the bottom of the pan with a wire to look for particles and shavings of metal. Oil analysis can also be done professionally to assess material in the oil that indicates failure. If it is in the "bottom" of the engine, it is probably a Main or rod, In that case it is an out of frame rebuild. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
