Posted by John T on November 12, 2007 at 06:02:52 from (66.244.83.147):
In Reply to: Spark plug gap posted by Mike CA on November 12, 2007 at 00:05:03:
Mike, Myself n others have spoken on this subject for years, not sure if everyone ever agrees lol its almost like politics. Id agree the 3116 is better then the 386 in an antique tractor application cuz its a NON RESISTOR plug and far as I know its heat range is somewhat higher then a 386 sooooooo its BOTH hotter and non resistive.
As far as the gap, I see that as very much related to the rest of the ignition system, especially the coil, as a primary concern regarding whichever plug one chooses. As youre probably aware as the gap widens the spark can change from a hotter blue to a yellow spark, so the best trade off where the spark is plenty hot but the coil voltage is operating where it and the rest of the system was designed for probably yields the best gap choice. Only way I see to teat all this would be hooked to a Dyno but thats also gotta be weighed against the coils specs and its service life as if its overworked she may develop a few more HP but at the expense of earlier coil or points failure?????????
Sooooooooooooo all that being said, and as the owners manual recommendation is based on the entire ignition system (especially the coil) and its capabilities n limitations........ and the gap distance is more important then whatever brand plug is used,,,,,,,,,,,,,,
I AGREE WITH RUSTY, ID GO WITH WHAT IT SAYS
I think resistive versus non resistive plugs and their heat range is more important then what brand plug one uses and one primary cause of premature fouling is when we light duty use n parade thes old tractors around verus using them loaded and keeping the temp up to 180 and higher. Keep the ignition well tuned, dont run the carbs over rich, keep the temperature up and use a hotter range of non resistive plugs should help.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
