Posted by John T on November 14, 2007 at 05:39:55 from (66.244.83.147):
In Reply to: Magneto vs. Coil posted by bullfrog on November 14, 2007 at 02:58:17:
Frog, Its a Piece of Cake. All youre doing is running a switched (dash mounted On/Off Ign Switch) hot ignition wire down to an external coils input (NOT to distributor) terminal and run the coils other output terminal into the distributors points n condesnor connection/terminal. The ignition switch can get its BAT input voltage from the load side of an ammeter or the L terminal on a 4 terminal Voltage Regulator.
Just match the coil voltage to whatever voltage the tractor battery is (i.e. 6 votl coil if 6 but 12 volt coil (or a 6 with an external series ballast resistor) if a 12 volt battery) Also match the coils +/- polarity to that of the battery, i.e. if at Pos grnd the coils - gets voltage from the switch while its other + wires to distributor or if at Neg ground the coils + gets switch power and its - wires to distributor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
