If the three point and remotes just up and stopped working then there is a good chance that ya sheared the key on the main pump . Drain the rear end and remove the pump , then remove the gear and see if the key sheared . But if what ya say about the steering and brakes not working wright here as not sure what ya mean for sure . Before ya do anything then check and make sure that the PTO is still working under load . If that is not working them my best guess here is ya did what i did last friday and took the center out of the pressure plate and maybe along with the PTO input. IF this is the case then a split at the bellhousing is in order . Hard to fix a tractor over the keyboard with out checking it out first. Don't think it is a valve .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
