Posted by James Williams on November 22, 2007 at 05:27:37 from (74.46.215.178):
In Reply to: F-20 engine rebuild posted by Scott Rukke on November 21, 2007 at 18:12:18:
Scott,Throw the spes away,Ive redone several of these.I have used plastic gague and set the rod bearings at .004.But cowman is right add or remove shims as needed while cranking the motor.Try to keep the shims seperate and put them back as they come out,this will give you a good start.as for rod bearings tighten them tight and install cotter pins.After tightening a few you will get a feel for the torque.I torque the head bolts at 90 lbs run it for awile and tighten each one just a little more.With the motor complete in the tractor a torque wrench wont fit in some places than use a wrench and go by feel.I was told by a person that visited the assembly line several times that he never seen a torque wrench in the factory.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
