Posted by glennster on November 23, 2007 at 13:50:50 from (76.224.26.7):
In Reply to: 1939 A posted by MTC on November 23, 2007 at 13:42:12:
two things come to mind that would be (easy) ???? fixes. first, head gasket leaking, second the o rings at the base of the cylinder sleeves are leaking. drop the oil pan, fill the radiator and look for leaks at the cylinder bottoms. if you want to try and pressurize the cooling system to check for leaks, get a bicycle innertube for a fat tire bike, cut thru it opposite the valve stem. hook one end to the lower rad outlet on the motor, add antifreeze to it and hook the other end to the top going in to the block. pump it up with a hand tire pump, get 5-6 psi of air pressure in there and check for leaks. you need a couple hose clamps on the innertube too!!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
