IT DEPENDS Its muchhhhhhhhhhhhh safer if you simply jump the STARTER ONLY (if switch and wiring type permits the same) without backfeeding 12 volts back into a 6 volt electrical system.
I WOULD NOT JUMP A 6 VOLT BATTERY WITH A 12 VOLT it could blow up.......
Keep polaritys matched..............
If theres no tractor battery at all and its a battery/coil ignition if you run it at straight 12 volts for too long the coil will overheat unless you add some external series ballast but if its a mag its not wired to any battery power.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
