Posted by old on November 25, 2007 at 08:24:56 from (4.245.6.238):
In Reply to: 46 A Carb Problems posted by Aj Clark on November 25, 2007 at 07:31:09:
Well first off did you just open it up and try to clean it or did you put a kit in?? You need to go the lit route. Then if you did put a kit in did it have a rubber tipped float needle?? If it did you need to take those and seat the needle or they will leak most of the time and cause flooding. You seat them by tapping in the needle with the float out but the needle in the seat. Aslo you need to make sure the needle seat is real tight or they leak. Setting the float lower doesn't help most of the time it hurts because it doesn't have enough gas in the carb to run the engine. Also does choking it help or hurt. If it helps you probably have a clogged main jet if it hurts then you have a problem with the float seat or float
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
