Posted by Steven f/AZ on November 25, 2007 at 10:49:43 from (24.121.167.138):
In Reply to: Gas $$$$ at $4.10 posted by Coax on November 25, 2007 at 10:35:47:
In theory E85 should be able to be used... you will need to be sure that any rubber parts of the system are compatible with the alcohol and you will need to richen the mixture quite a bit as ethanol has fewer BTUs than gasoline. It also has a higher octane so you could rebuild with more compression and/or increase the timing advance.
I can't wait to see someone make this work!
And that price isn't far off... my brother in ND filled with #1 clear diesel fuel the other day for $4.17 per gallon!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
