Starting in fifth is pretty hard on the clutch, and I recommend a shift from 4th to fifth. Make it a slow shift, and it will grind just a little. It is best to double clutch it. Idle down as you pull it out of 4th, then let the clutch out briefly, push in the clutch and then slip it into high. This is hard to do unless practiced. Are you positive you have the carb and governor coupling together at the carb connection, it is tricky little metal fingers, and causes related problems, some of which sound like yours. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
