The easiest solution is to compress the clutch pressure plate using three of the 6 mounting bolts. remove every other one, and put them into the clutch cover (pretty obvious visible spot) As they are installed and tightened (not all at once, do it in stages) the fingers will move forward allowing additional wiggle room in the shaft. It is still a case of geometry and juggling. If you try to put it together wrong, it will be very frustrating. Look at the diagram and it will go in, no split is needed. To replace the clutch yes, to put in the shaft no. The holes are remnant access holes for a belly pump Liftall system your tractor may have had at one time, or possibly never had. The space can often be used for a hydraulic reservoir if one is fabricated to fit the space and hole location. I hope this helps. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
