Re: Farmall M Pistons
Posted by D Slater on December 02, 2007 at 16:19:43 from (72.65.155.230):
In Reply to: Farmall M Pistons posted by Paul Mockensturm on December 02, 2007 at 07:32:59:
Most step head pistons have part of the top on the side toward spark plugs raised above rest of piston and the top of raise is flat and exstends all the way across the raise. IH fire crator pistons for a M used 2 raised humps with a crator or dip between. M&W turbo dome pistons for M used 2 raised areas with a slot between. IH and M&W sold several different compression pistons acording to altitude wanted or cylinder head used. IH sold several power improvement packages for M tractors. One gave about 4 1/2 HP improvement with 3 7/8 pistons, then they went to 4 inch overbore packages then fire crator. Some complete fire crator kits for M contained distributor advance parts and different metering for carburetor along with P&S set. If flat part of pistons have the same deck height the step head pistons can be made to give more compression that may or may not mean the most power compared to M&W or IH fire crator type if flame front is blocked by the step. Different heights of raises or steps could give both types a advantage over the other when compared in different engine set ups ups. Sealed power and perfect circle used to sell pistons that almost matched the fire crator ones IH sold. Not sure if either company is still around myself. IH used to sell for M fire crator kit 374260 R91 standard alt. and 374506 R91 high alt. Not sure but think they only have some pistons and sleeves now with no complete kits. M&W used to claim 53.8 horse power for a standard alt. gasoline M with there 4 inch bore kit.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
