THe backlash can be adjusted at anytime. The issue is tooth and bearing/bushing wear. If the teeth are looked at with a hand maginfying glass, and there3 is little pitting (spalling from lack of lube/rust water and humidity from no operation for long periods) no micro dents (brenelling is caused by hard broken buts of metal betweem parts)and the drive flank has little if any wear showing, the gears are probably servicable. If the bushings and thrust washers are clean scar free, and have only .001 to .003" clearance (AN APPROXIMATION) It is good to go. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
