Posted by gene bender on December 08, 2007 at 17:13:50 from (67.55.226.214):
In Reply to: Timing a MAG posted by rdb on December 08, 2007 at 17:03:31:
First thing before the mag is installed turn it over and with the cap off make sure the rotor lines up with the tower on the cap when it fires. Then when you have #1 on the compression tdc you can install having the rotor pointed to the wire going to #1. Since the drive is a slotted type thing the worst you can be off is 180deg. With the plugs out and using the cramk you can determine if you have installed it correct by turning engine over and watching when it impulses. There is no advancing timing as it will impulse on tdc then when engine runs it will go to 34deg advance nothing in between good luck.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
