Posted by ScottyHOMEy on December 10, 2007 at 08:17:31 from (71.241.213.254):
In Reply to: Super C Clutch posted by CTjohn on December 10, 2007 at 07:30:29:
I had the same problem on my BN after a rebuild, the tip of the rod hitting the adjusting bolts on the clutch. Didn't make any sense. Fingers were set right, freeplay was about right. I finally chased down what had changed. The dowel that holds the top of the bearing fork looked to be driven further in one side than the other. I tapped it back the other way to center it up. No reason, if everything is straight that that should have changed any thing, but it fixed it. Might be worth a looksee in your case.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
