A 340 has an engine design with wet sleeves. The method is to have the crank set so two are up and two are down. Remove the rod caps, and take the piston and cylinder out at the same time by driving them upward with a 2"X2" stick of hard wood and a mallet from below. Be careful not to nick the crank with the loose rod big end. Once they are an inch out, they are out. Clean the grooves for the O rings very well, and use new O rings lubed with silicone grease, or straight dish washing detergent. Make sure the rim relief in the deck of the block is also very clean. A bit of LPS corrosion inhibitor sprayed in that recess is good. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
