Re: cylinder sleeves
Posted by Janicholson on December 13, 2007 at 08:59:13 from (199.17.6.122):
In Reply to: cylinder sleeves posted by mark3006 on December 13, 2007 at 08:45:49:
The making of the tool is really the only good answer. The puck should be bore size then step to bore size plus .090"
Then a 3/4" hole for ready rod in the middle.
On the top, a bridge made from 2X4" rectangular tubing and blocking or a pipe bigger than the sleeve flange to pull up against provides the pull. use heavy class nuts on the ready rod.
Some use a welder to make four passes up the walls of the sleeve from bottom to top these shrink the sleeve when cool, allowing easy removal. Protecting the journals is important, and not welding too deep causing bore dammage to the casting is also important. I would make (or have made) the puller. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
