Posted by Fromjb2 on December 16, 2007 at 19:08:03 from (99.241.179.24):
In Reply to: Re: 674 IH TRACTOR posted by Robert Hasserd on December 16, 2007 at 13:32:04:
Robert, according to I&T Shop Service Manual. 1)Remove pressure line going to PTO clutch at tee and connect pressure gauge. 2)With warm hydraulic oil and PTO engaged, run tractor at 2200 RPM and check for pressure of 220 psi. If pressure is low remove the plug on top of MCV valve to the right of the PTO spool valve and add shims till pressure is minimum 220 psi. 3)Reconnect pressure line and remove cap from tee and connect pressure gauge. Run tractor at 2200 RPM with PTO engaged and if sealing rings and PTO clutch are good, pressure should be 220 to 250 psi.
Since you had one stuck pressure regulator in MCV maybe PTO pressure regulator is stuck as well.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
