Re: I'll let you all troubleshoot this one.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red. FOUND THE CULPRIT! on February 24, 2000 at 14:15:44 from (12.75.47.114):
In Reply to: I'll let you all troubleshoot this one. posted by The Red on February 23, 2000 at 06:19:18:
I got the fuel gauge pulled from the tank and it was almost rusted through. Got a small flashlight in the inlet hole and the tank is very rusty. I then examined the new strainer assembly. The inlet pipe to the cut off valve was PACKED, not with playdo type gas, but RUST! I pulled the cutoff assembly out and have the valve and strainer assembly soaking in gas. The rust is loose so it should clean out just fine. I will get the tank to the Plainfield IN radiator shop which specializes in boiling and sealing gas tanks. I will also pull the carburetor top. If it has rust in the bowl, then the 10 feet of gas line from the fuel pump to the carburetor is rusted inside. Two Deere dealers supposedly have the original rigid lines but I can get custom ones made if I need to. Thank you for all your analysis which was quite good. I will rebuild the carb and soak it in carb cleaner if I find rust in the bowl. Many Thanks Farmallers. :)
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
