Posted by Fromjb2 on December 20, 2007 at 13:16:39 from (99.241.179.24):
In Reply to: 454 shifting problem posted by Harold Kelley on December 20, 2007 at 07:17:42:
Hi Harold is the grinding into high range from a stop or while moving? There is no synchromesh between lo & high only 1 thru 4. As for jumping out of high range, I would check the adjustment on the range transmission control rod. Re sticking clutch unfortunately that is one of the problems with the new metallic pads on the clutch disk. Any moisture or high humidity and the pads will rust to the pressure plate and flywheel. Same happens on cars & trucks with disk brakes. Give me the old asbestos pads.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
