Posted by Marty K on December 21, 2007 at 07:08:28 from (128.251.109.118):
In Reply to: adjusting 450 clutch posted by Hoss357 on December 21, 2007 at 04:09:55:
It's been a while since I adjusted mine after getting a new disc for it, but I'll give you my two bits. I'm assuming your clutch and flywheel are together in the tractor. You have to back off the lock nut and turn the adjusting screw for each of the three fingers that press against the throw-out bearing until there is just clearance between the fingers and the bearing face. It's hard to work under the tractor in that small opening into the clutch housing so be patient. Try to get the spacing even between the fingers and the face of the bearing so the clutch disengages evenly. Adjust clutch pedal play with the turnbuckle on the clutch rod.
My original adjusting screws had hex heads on them, but the replacement had slots for a flat screwdriver which makes it near impossible to adjust on the tractor. I put the old hex head screws back on so I could adjust it with everything all put together. I've attached a poor picture of the flywheel with the clutch installed and you may be able to see the finger adjusting screws. I hope this helps a little.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
