If you've got an electric hydraulic pump in the truck and the C has been converted to 12V electrical, you can just hang that off the tractor, wire it up, and use it just like you did on the truck.
You can also use the tractor's hydraulics by installing a bypass block and a two-spool open-center hydraulic remote valve. The cylinders on the plow aren't anything special. Just drain the old oil out of the cylinders and hoses before you hook them up to the tractor, as it may be incompatible with the HyTran in your tractor's system. You'll also need to refill the hydraulic reservoir on the C a couple of times as the air gets purged out of the hoses.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
