You're definitely going to have to split the tractor to get at the flywheel itself. The clutch will come out through the belly cavity, and it really isn't all that bad.
1. Remove the belly pump if so equipped.
2. Remove the four coupler bolts for the transmission shaft.
3. Remove the two bolts clamping the throwout bearing fork to the shaft. Catch the thick washers that key into the shaft.
4. Unhook the throwout bearing return spring.
5. Unhook the clutch linkage on the outside.
6. Pull the shaft out the side of the tractor.
7. Gradually remove each of the 6 bolts holding the pressure plate to the flywheel, a little at a time, all the way around.
8. Wiggle, twist, and cuss to get the transmission shaft out of the clutch plate. It's a tight fit to get the two halves of the coupler past each other.
9. If the pressure plate and clutch don't fall out and hit you on the head, finesse them out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
