George, Running clearance is the clearance between the item in mention (camshaft, crankshaft journal) and the bearing material. Or, the oil clearance. .002 inches total(.001 per side), aprox, is considered normal.
This allows room for the "oil cushion" to exist. If the clearance is too small, not enough oil cushion will exist and scuffing may occur.
If the clearance is too big, in the case of a rod or main bearing, it can make noise. In the case of too much clearance in a cam bearing, it usually just leads to lower than desireable oil pressure.
Many people check for proper oil clearance by using something called "plastic gage", a special plastic string you smash between the bearing material and crankshaft journal, then measure the width of the smashed string using a scale provided.
The resulting width is in direct proportion to the clearance (supposedly). Myself, I like to use micrometers and measure the inside diameter of the bearing as assembled (assemble the rod with the bearing shells, torque the nuts and measure the ID with a inside mic or telescoping gage), then subtract the OD of the journal (measure with a micrometer).
In the case of cam bearings, using inside/outside micrometers is the only way to properly measure the clearance.... for obvious reasons.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
