Posted by Chuck's Repair on January 01, 2008 at 13:18:51 from (162.40.106.161):
In Reply to: 826 PTO posted by Bradford on January 01, 2008 at 10:33:23:
There are two things that would cause the clutch discs to weld together.One would be low hydraulic clutch pressure to the cluth pack which can be checked and adjusted after the PTO is reassembled.The other is caused by normal wear on the clutch pack with normal hydraulic pressure and the apply piston coming against the the travel limit snap ring.Once that happens the piston can travel no further and any aditional wear on the clutch pack will cause them to slip and get hot.If the hydraulic pressure is set at about 235 PSI you should be able to kill the engine without the PTO slipping.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
