Dad always told me it is better to hear the tappets click than not hear them. Steel pushrods expand(Get longer)more than iron engine blocks. That is why they have a hot spec. If pushrods were made from cast iron, I think you could set them at a cold spec. If steel pushrods are set at a spec cold , it would depend on ambiant temp which varies greatly and adds or subtracts to the lenght of the pushrod so it would be tough to come up with a "set" temp for adjusting the valves. The hot spec is so the metal is already expanded at working temp where it will be running at most of the time. Too much gap will not let the valves open all the way and lose power and set too tight will let the exhaust pass by the valve and burn them and also may make it harder to start from loss of compression and from sucking exhaust gas back in when it is supposed to be sucking gas mixture in, less mixture= less power. It is possible to set valves at a cold spec, but you would have to figure ambiant temp, running temp, steel expansion and contraction rates and the engine block expansion and contraction. Much easier to just do it when all expansion is done and not burn valves up and have to pull the head off and replace parts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
