Posted by Owen Aaland on January 03, 2008 at 14:37:23 from (65.165.246.41):
In Reply to: 450 PRESSURE PLATE posted by Hoss357 on January 03, 2008 at 10:24:05:
The IH adjusting tool for pressure plates consisted of a round steel table with a threaded rod in the middle. The pressure plate is put over the rod so the friction surface is on the table. Spacers for the pressure plate you are working on are placed on the rod along with a step plate that contacts the fingers. The plate and spacers are drawn down tight to the table and then you use the correct spacer block to measure between the table and the clutch cover at each mounting bolt hole. Adjust the levers until you get the correct fit under each location.
Rebuilders often use just the opposite approach by clamping the clutch cover around the outer edge at a specified height and then adjusting/grinding the levers to get a very precise adjustment, often within a few thousands of an inch.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
